1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
coilover/lowering spring question.
Old May 17, 2007 | 02:23 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Default coilover/lowering spring question.
Hey everyone, i have heard in the past that if you are going to lower your car, if you are a daily driver, then go with lowering springs and if you just use it for show go wiht the coilovers... why is that? what is so different between the coilovers and springs besides the fact that coilovers you can ajust the height of ur ride and springs cant?? so y springs for daily drivers.
Old May 17, 2007 | 03:29 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: coilover/lowering spring question.
https://dodgeforum.com/m_813392/mpag.../tm.htm#813392
That should answer most questions
Old May 17, 2007 | 11:15 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
That's a good write up too BV... I highly recommend looking at that link.
The bottom line to coilovers vs. springs in terms of ride quality is that lowering springs keep a good amount of road shock off the the body and off of your body. It lowers the car but retains a good amount of the stock ride feel.
Coilovers on the other hand will be very stiff and uncomfortable for most that like a smooth ride. This is assuming that you get the correct spring rates. You don't want to get spring rates that are less than the originals.
In terms of modifications..BV write up states it all IMO.
Old May 17, 2007 | 11:46 PM
bad venge's Avatar
bad venge
Section Moderator
I thought I posted it before but couldn't find it ... It's been a sticky for a few years ...
Old May 18, 2007 | 12:26 AM
silvercoupe97
Uber Moderator
I thought I made that a FAQ already? Oh well, I just did, lol.
Old May 18, 2007 | 12:40 AM
bad venge's Avatar
bad venge
Section Moderator
I found it in the othet DIY section
Old May 18, 2007 | 02:14 AM
blackvenge34's Avatar
blackvenge34
yea i put coilovers on my car beside the fact that they were 70 ebay ones but i dropped it as low as it could go without the kit i felt like i was in a gocart bounced like crazy i got annoyed so i went with springs and now i had my kit and i got tired of scraping so its back to stock now
