1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Coil/PCM?
Old May 17, 2007 | 11:24 PM
Schrum's Avatar
Schrum
Default Coil/PCM?
Is it possible that a bad coil could blow out my PCM? When I changed my coil, that didn't fix my problem so I just returned my new coil. Then the dealership said that my PCM was the cause so I changed that twice. I figured that my old coil could do this to all of the PCMs that I put in it.
Old May 17, 2007 | 11:47 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Coil/PCM?
I doubt it could blow the PCM There is no feedback path
Old May 18, 2007 | 06:24 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Are you still having issues with this car Schrum? This is a 2.0L auto correct? Are you getting fuel then, since you're working on spark?
So far what have you done/checked?
Old May 18, 2007 | 05:40 PM
Schrum's Avatar
Schrum
Yes it is a 2.0 but manual. When I started having the problem in Feb. I replaced the coil twice, crank sensor, cam sensor twice but with used ones from running cars, these parts didn't help so I returned them. Then took it to the Dealer and they replaced the PCM twice and told me to get it off there property. Yesterday I put a used working coil and wires on from my friend's SRT and a new ASD relay. Everything keeps leading back to the PCM.
Old May 18, 2007 | 05:41 PM
Schrum's Avatar
Schrum
Ohe yeah, still no fuel or sparkin cyl# 1,2, & 4.
Old May 18, 2007 | 11:36 PM
rthegremlin2's Avatar
rthegremlin2
possibly a bad wiring harness? Have you checked for burnt wires from the cam sensor? Any codes?
Old May 19, 2007 | 03:41 PM
Schrum's Avatar
Schrum
I don't know if I am getting any codes because it wont start. I wasn't getting any code before it stopped running. I will check the wire from the cam sensor but it looks OK.
Old May 20, 2007 | 02:55 AM
shooter5045's Avatar
shooter5045
have you checked the wires to the Crank senser?
