96 Avenger 2.0 to 2.4 swap
I have started to replace the 2.0 engine with a 1998 Breeze 2.4 engine. It looks like a harder job than I thought. Do you know if any front mounts will bolt to the 2.4 and to the Avenger without being modified? Also I would like to use the Breeze Automatic instead of the Avengers stock automatic. Will this work or what will need to be changed? I have the whole 1998 Breeze car and another 1998 Avenger parts car. I have already put the 2.0 DOHC head on the 2.4 which was also A DOHC head. I can see the 2.4 does not have the mounting for the bracing to support the 2.0 fuel injection intake and I will need to build that. The power steering, Air conditioning and alternator brackets are a puzzle at this time as well. Any help would sure be helpful.
There is only one person I know of that has swapped a 2.4 and he's on another forum that I'm not allowed to mention (by this forums rules )
PM me for info/contact
here's some links:
http://aseclub.net/forums/index.php?...=97388&hl=
http://aseclub.net/forums/index.php?...=67755&hl=
https://dodgeforum.com/m_766377/tm.htm
http://www.angelfire.com/va3/97_420a/swap/
http://www.dsmsource.com/forums/showthread.php?t=67296
Hope some of the helps
