1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Engine making clicking noise...
Old May 31, 2007 | 12:59 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Engine making clicking noise...
What does the oil pressure gauge show ??? what oil you running ??? With the motor running carefully remove the oil cap and look at oil flow in the head ....
Old May 31, 2007 | 11:24 AM
Nelson9937955's Avatar
Nelson9937955
Gauges are all normal and flow looks normal. I have been running 5W30. I am do for an oil change. I am thinking about trying some top cleaner or kerosene to see if that helps
Old Jun 6, 2007 | 12:50 PM
mmatheny's Avatar
mmatheny
Run some engine oil flush through the engine, drain, add good oil. Mine has ticked at idle since I had it after the oil gets used. It is most probably a sticking lifter.
