1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
NO AUDIO
Old May 30, 2007 | 01:14 AM
Tsid420's Avatar
Tsid420
Default NO AUDIO
I put in new batt and alternater and now im soundless. But it done it before the new alternater was in. i have a stock infinity amp and stereo and the cd player and radio work fine. i can change cd tracks and see the counter ticking up. and i can tune in radio stations. all this and NO audio. I have checked all of my dash and underhood fuses.And my stereo doesnt say anything about a code.PLEASE help out...or do i just need a new amp and stereo with some state of the art tsunami wiring??? Im driving a 99 avenger es
Old May 30, 2007 | 03:35 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: NO AUDIO
Check for 12 volts at the amp (thicker gauge wire forget the color red???). Also check the remote wire at the amp for 12 volts (white wire/black/silver dots
Old Jun 6, 2007 | 12:53 PM
mmatheny's Avatar
mmatheny
I had the same problem on my 95 - turns out there is an in-line fuse (not in the fuse block) for the Infinity amp in the trunk, took my dealer forever to find it - they even changed the radio head in the dash before they finally found it. I don't know exactly where the fuse is though!
