1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
HELP ME BV
Old Jun 8, 2007 | 07:01 PM
josef15111's Avatar
josef15111
Default HELP ME BV
Hey man i cant get my remote start to actually start the car. It cranks and turns my radio on but it dont turn the dash lights on and wont start? what would cause this ????
joe
Old Jun 8, 2007 | 10:29 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: HELP ME BV
Well what BRAND dou you have ??? has it worked before ??? New install ???
Old Jun 9, 2007 | 01:09 AM
josef15111's Avatar
josef15111
ok so i got it working lol. i was haven one heck of a rough time doing this install it has like 50 wires to it. it was my tach wire i had to tape in to the white wire at the pcm and it works now. one thing the i need ta know the right wire for the ligths. i tried the green wire at the light switch in the igniton spot and nothing. which green wire is it underneath down in the kick panel do you know??? and for my auto windows up option how do i get that to work?? do i need a relay cause it cam with a relay and a harness for the relay. here is a link to which one i have maybe it will help out..
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220116299334
thanks BV your a great help around here..
Joe 95 es
Old Jun 9, 2007 | 01:20 AM
bad venge's Avatar
bad venge
Section Moderator
I figured it was tach related ...
1995-96 Dodge Avenger Security Information
Parking Lights
Green/White
Left of Steering Column
Head Lamp
Red (-)
Steering Column Harness
Windows Up
LF=Green/Red, RF=Brown/Yellow MAIN
Windows Down
LF=Green/Black, RF=Green/Yellow
Since I've never touched that one I have no idea on the windows up ( I only do Viper DEI)... Here's the wiring for the alarm I get the lights as listed in the steering column
Old Jun 12, 2007 | 04:48 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Well hey i am also encountering a similar problem with my keyless entry/engine start remote... but mine will not lock and unlock... i have a Xplore XR-7025.. if anyone is familiar with this.. please reply back and i will explain what i did to not make it lock and unlock.. and now if i try to unlock it with my key then it will unlock the actual car alarm system. but my keyless remote system still says its locked and flips out and the alarm wont stop going off.. so i unplugged the battery cable to shut it up.. and every time i try to put it back on the damn alarm keeps going off.
Old Jun 12, 2007 | 05:15 PM
bad venge's Avatar
bad venge
Section Moderator
After unplugging almost ALL alarms go of automatically .Otherwise theives would disconnect the battery and plug it back in disarming the alarm... Hit the button to disarm it it should reset ..
Old Jun 12, 2007 | 06:00 PM
dynamiteplaya3
it will disarm it, but it still wont lock or unlock the car... i even took out teh whole security box and plugged it back in.. it worked for about a min. and then stopped.. now it will not lock or unlock again
Old Jun 12, 2007 | 08:06 PM
bad venge's Avatar
bad venge
Section Moderator
Does it have a Valet switch ???
Old Jun 12, 2007 | 10:48 PM
dynamiteplaya3
umm. idk ha explain to me what that is?? well what i did to cause this problem was.. i was clicking the middle button which illuminates the choices on the romote one at a time.. i never really got to know what all the buttons meant so i illuminated the car. and the arrows on both sides started moving back and forth and since then my car will not lock or unlock or start (from the remote!!!)
Old Jun 13, 2007 | 07:38 PM
bad venge's Avatar
bad venge
Section Moderator
sounds like you did something via remote ... break out the manual and see if you can reset it
