1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
removing wiper arms
Old Jun 11, 2007 | 04:45 PM
cbccadet2002's Avatar
cbccadet2002
Default removing wiper arms
I have the manual and it says remove the black caps, remove the retaining nuts, then the wiper arm should come off. i tried to pry up on the arm but couldn't get it to budge. I didn't want to crack the cowl cover. Any one have any tricks or tips. I'm trying to change out my hood hinges. thanks
Old Jun 11, 2007 | 05:12 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: removing wiper arms
PENETRATRING OIL .... Lots of it ... The Arms are aluminum and the shafts are Steel the two metals corrode badly ....
Spray leave sit pry back and forth ... If all else fails I've used a gear puller to get them off
Old Jun 11, 2007 | 07:23 PM
73dart's Avatar
73dart
Put a little anti-sieze on them when you reinstall and it will help the next time you take them off.
Old Jun 12, 2007 | 07:12 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Anti-seize on the two surfaces not on the bolt threads. The two surfaces are what corrode.
Funny thing is, I've done everything to get the wiper arms off and I've still not been able to get them apart. I'm almost to the point of just getting another set, used or new, and just breaking the old ones off, lol.
I'm going to try again soon and if that still doesn't work......
Hey BV what puller do you recommend to use? I've used 2 armed gear pullers but none of the ones I've used had thin enough arms to fit down the sides and they just kept popping off.
Bah, I've got a few more tricks to use before giving in, lol.
Old Jun 12, 2007 | 01:39 PM
bad venge's Avatar
bad venge
Section Moderator
I've got a two arm with a nut on top that pushes the arms in tight to not pop off ....Another nut tigtens it to push it off
Old Jun 12, 2007 | 10:32 PM
silvercoupe97
Uber Moderator
Do you have a pic of it? Where did you get it?
Old Jun 13, 2007 | 12:03 AM
73dart's Avatar
73dart
Try vinigar on it the light acid might be enough to dissolve some of the corrosion.
Old Jun 13, 2007 | 12:25 AM
silvercoupe97
Uber Moderator
ORIGINAL: 73dart
Never thought of that one, good call. I guess, soda can be used too, since it has acids in them also.
Old Jun 13, 2007 | 03:23 AM
cbccadet2002
thanks i should known this from being a machinist. lol. I over steered a corner and smacked the side of a cliff. i put a 95 bumper on a 98(i like the 95 better actually), it doesn't line up perfect with the lights though. i got a new hood latch so now my hood closes. But my hood is cocked towards the drivers front. I got some hinges off a 95 so im hopin that will line it back up. Any other ideas?
Old Jun 13, 2007 | 03:58 AM
silvercoupe97
Uber Moderator
The headlights should be swapped to the 95-96 style also, that's why the bumper doesn't line up with the headlights.
As for the hood, try moving the hood stops on each corner. The driver's side could be higher and it may be pushing that corner up higher, or the passenger side could just be too low, lol.
