1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Brake rotos
Old Jun 12, 2007 | 08:32 AM
GustiX's Avatar
GustiX
Default Brake rotos
Hi
I need to replace my rear brake rotors. Do you know if they will fit from
Eclipse? The reason I ask is that it is very hard to get Dodge parts
where I live (Iceland) but Mitsubishi parts are easier.
Cheers
Agust
Old Jun 12, 2007 | 01:38 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Brake rotos
Yes 95/99 Eclipse (NON AWD) fit
Old Jun 13, 2007 | 03:30 AM
cbccadet2002's Avatar
cbccadet2002
front and rear?
Old Jun 13, 2007 | 04:06 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
The N/A Eclipse use the same breaking system the AvengerSebring does. The AWD Eclipse/Talons use a twin piston caliper up front (which can be used as an upgrade for Avenger/Sebrings btw).
