1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Time for new Brake Pads? or Shoes?
Old 06-18-2007 | 10:30 PM
odel0022's Avatar
odel0022
Default Time for new Brake Pads? or Shoes?
Hey guys
I am getting almost like a grinding feel whenever I apply the brakes and the harder I push down on it the more it seems to feel grinding. This is a common symptom of worn brake pads?
Old 06-18-2007 | 10:38 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Time for new Brake Pads? or Shoes?
Yes ... pull the wheels and look ....normally the wear indicators screech before you reach the grinding point though
Old 06-18-2007 | 10:39 PM
dynamiteplaya3's Avatar
dynamiteplaya3
well if its more of a squeal than a grind than it would be pads. im guessing it could be the rotors... they might be warped.
i would get a new set of rotors and some new pads to go with it..
Old 06-19-2007 | 03:41 AM
blackvenge34's Avatar
blackvenge34
grinding is no good id say new rotors as well i had to replace rotors n padson my moms van a month and a half ladter they started grindingagian turns out frozen calipers check to see if they calipers are frozen as well if one set of pads arelower then the other then that could be the case i think
Quick Reply: Time for new Brake Pads? or Shoes?
