1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
need help with misfire problem
Old Jun 19, 2007 | 04:12 PM
njb10's Avatar
njb10
Default need help with misfire problem
alrighty, i jus got a new 97 dodge avenger es 2.5L. I changed wires, plugs, and got a new distributor. I first changed the distributor and it ran like a charm. i then changed the wires and plugs and it started to back fire. the check engine light dont come on until i turn on the car. wat does that mean.
Old Jun 19, 2007 | 05:03 PM
autoguru77's Avatar
autoguru77
Default RE: need help with misfire problem
Double check your wires to ensure the right wire goes to the right plug. Also check your plugs-mainly the gap-make sure if you accidentally dropped one of them that it isn't cracked. What brand wires and plugs-If you bought them at autozone........take them back and find a better parts supplier!!!
Old Jun 19, 2007 | 05:35 PM
njb10's Avatar
njb10
i did by the ones from autozone. then which ones do u suggest i buy.
Old Jun 19, 2007 | 07:23 PM
bad venge's Avatar
bad venge
Section Moderator
I'd check that the wires are seated properly FIRST .... Push them down on the plugs and at the dist. cap ....
Old Jun 19, 2007 | 08:33 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
The most obvious thing is that the backfires didn't start up until you changed the plugs and wires. There's only so much that could be wrong with those two.
I agree with the things mentioned by above. Be sure that you placed the wires on the right plugs and make sure they are seated properly, if that doesn't solve the issue, check your gapping on the plugs.
If none of that works, what brand wires and plugs did you buy?
I'm pretty sure the CEL is going to say something about the misfire but it never hurts to do the keydance for the code(s) anyway.
