1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
manuel trans conversion
Old Jun 27, 2007 | 06:48 AM
Zephrical's Avatar
Zephrical
Default manuel trans conversion
Sorry if this is a repost but i was looking for some upto date info.
I am looking to convert my 95 venger es to a stick but have heared it can only be done with and swap to a 4cyl. is it possible with a v6 and also if rwd is in the question for a conversion? Thanks a ton
Old Jun 27, 2007 | 02:08 PM
kog523's Avatar
kog523
Default RE: manuel trans conversion
All I know is that I have a 95 manual it is a 4 cylinder and it is front. Questions about the swap I don't know but I know that when I was looking at diffrent venge's I can't remeber seeing a 6cylinder manual.
Old Jun 27, 2007 | 03:13 PM
bad venge's Avatar
bad venge
Section Moderator
ANYTHING is possible with enough $$$ and Time ....
Rear wheel is possible if you find an old direct connection rear wheel drive kit (turboZ's and Chargers) that will give you a good start ...
There is no V6 Stick either swap or from Dodge ... It has been tried many times there is one promising try on ASEC but his tranny was junk out of the yard and lost interest (lack of $$$) to continue
Old Jun 27, 2007 | 08:35 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Jaded gave up? Really? Well, I guess, it'll be another couple years before it's attempted again, lol.
That really is too bad.[>:]
Old Jun 27, 2007 | 10:29 PM
Zephrical's Avatar
Zephrical
thanks guys
