1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Higher performance alternator needed?
Old Jun 27, 2007 | 12:16 PM
Nelson9937955's Avatar
Nelson9937955
Default Higher performance alternator needed?
I am upgrading my stereo system to where I will be gettingabout 1500 rms total. I have a 1998 avenger V6 automatic. Do you think i will need to upgrade the alt to handle this? And if so, can you provide me with a link of where I can get one online?
Another option would be maybe just upgrading battery to this:
http://www.kinetikaudio.com/hc1400.asp
or is this a better option:
http://cgi.ebay.com/OPTIMA-RED-TOP-G...QQcmdZViewItem
Old Jun 27, 2007 | 03:09 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Higher performance alternator needed?
High Output (H.O.) Alternators
Powermaster
7501 Strawberry Plains Pike
Knoxville, TN 37924
Phone: 865-688-5953
Website: http://www.powermastermotorsports.com/index.html
Contact Name: Coy Hudnall ext. 250
MECHMAN
7076 Oak Hill Road
Hesperia, CA 92345-0730
Tel: (760) 956-7596
Orders: (Toll free call) (888) 632-4626
Website: http://www.mechman.com
Contact Name: Dennis Moore
QUOTE
We have three models that will fit your vehicle.
20-250-43G-1G ($392.00) rated @ 150Amps "HOT" (185Amps "COLD")
20-275-43G-1G ($454.00) rated @ 175Amps "HOT" (210Amps "COLD")
20-300-43G-1G ($534.00) rated @ 200Amps "HOT" (240Amps "COLD").
All require an adapter bracket kit ($50.00) and an adapter plug ($35.00) for the install. Should you have anymore questions, just call our tech support@ 760-956-7596 or email us. To place an order call 888mechman (632-4626) or email us.
Irragi alternators
n/a
LaVergne TN
Phone: 615-287-7991
Email: dominick@tds.net
Contact Name: Dominick Iraggi
H.O. Alternators
n/a
n/a
TOLL FREE: 1.866.446.8878
Website: http://www.h-o-alternators.com/index.htm
Ohio Generator
134 N. Chapel St
Louisville, Ohio 44641
Phone: 330-875-6677
Fax: 330-875-6688
E-mail Address: info@ohiogen.com
Website: http://www.ohiogen.com
This calculator will tell you the required alternator rating for your vehicle at peak usage. It may not be possible to meet these specs with a single alternator or even necessary to. Many other factors come into play such as driving and listening styles. It will however give you the ideal answer and a good indication of your present alternator's ability to supply your system. It takes into account the current draw of the OEM electrical accessories, the current draw from your amplifiers at peak draw and the current draw from any other electrical accessories (neon, fans, strobes...) in your vehicle.
Alternator Specs
Calculate the Required Alternator Rating for Your Vehicle
Input
Total Amplifier Power? 1500Watts
Amplifier Efficiency?
(Class A/B Typically 50-60% Class D 70-80%) 85%
Charging System Voltage? 13.8Volts
OEM Alternator Rating? (Typically 60-130Amps) 110Amps
Total Current Draw of Accessories Added Other then Amplifiers? 65Amps
Output
Required Current Rating of Alternator at Peak: 303Amps
Power Drawn From Charging System: 1765Watts
[/align]
Old Jun 27, 2007 | 03:50 PM
Nelson9937955
So based on 300 amps, i take itI need a pretty big alt? I was hoping I could slide with just a battery upgrade.
Old Jun 27, 2007 | 05:06 PM
bad venge's Avatar
bad venge
Section Moderator
That is WORST CASE ...
I'm running 2250 watts on a 180amp alternator ...
Upgrade the big 3 and an Optima battery
Old Jun 27, 2007 | 05:43 PM
Nelson9937955
ORIGINAL: bad venge
Ok thanks. I might just upgrade the batt for now and see what happens then. My equipment is in the mail but I am just trying to think ahead. i could also keep the gains down a bit in the mean time.
You know anything about these Kinetic batts? On different forums I have read they can outperform yellow and red tops
Old Jun 27, 2007 | 06:55 PM
bad venge's Avatar
bad venge
Section Moderator
kinetic stinger and odessey all make real good batteries
Old Jun 27, 2007 | 09:31 PM
josef15111's Avatar
josef15111
Yea man i will say upgraden my batt. was the best thing i did.. My lights and engine would die down so bad i thought the car was gunna die lol. Just got a new red top 34/75 and wow after a day of driving on the batt everything is working so nicely with out any dimming and i still needa finsh the big 3..
red top was worth it
Joe
Old Jun 27, 2007 | 11:36 PM
Nelson9937955
ORIGINAL: josef15111
Joe
How many total rms watts are you running in your system?
