1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
problem need advice
Old Jun 29, 2007 | 12:01 AM
00neon27sts's Avatar
00neon27sts
Default problem need advice
OK my mom has and 96 avenger her ex took it and had his boss look at it and he said the oil pump was bad so he brought it back here i started it upit is low on oil he also put trans fluid in it and when i started it up it has oil pressure so should i just clean it up real good put so good oil in with some lucus oil treatment init and give it a tune up or should i do something else? thanks in advance p.s. i used to own it then trade it for a neon because the water pump went out and i didnt have money to fix it but i love the avengers!!!!!!
Old Jun 29, 2007 | 12:19 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: problem need advice
I'd give it an oil change then see what the pressure looks like ... worst case your out 5 quarts of oil and a filter
Old Jun 29, 2007 | 05:26 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: 00neon27sts
The oil pressure is low and you put transmission fluid in it? Am I reading that right?
Old Jun 29, 2007 | 12:30 PM
00neon27sts
when her ex took it and looked at he put trans fulid in it i didn't i am smarter than that
Old Jun 29, 2007 | 01:07 PM
silvercoupe97
Uber Moderator
Gotcha...lol, some people eh.
Flush the oil and put in motor oil and then let us know how it goes. It sounds like the fluid was low and the ex put tranny fluid in because the oil was low to try and help the issue.
Old Jul 1, 2007 | 02:59 AM
Talyn's Avatar
Talyn
At least the trans fluid will give the engine a good cleaning.
Old Jul 6, 2007 | 02:48 PM
ommar's Avatar
ommar
Default problem with engine start up. PLZ help!
I have a 98 dodge avenger ES. it was running fine with no problem until recently i have problems with starting engine. Once I insert the key to start the car,. the engine keeps cranking and it wont start. i took for mechanics . they couldnt find the problem with it, meanwhile sometimes it just works normal, it starts normal with no problem, but lets say in the morning i wake up, it wont start at all even if i keep cranking for one hour, so basically it keeps cranking but it never starts, but after some time it starts with no problem. so somebody could help me with this issue?
tanks
Old Jul 6, 2007 | 05:24 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: problem with engine start up. PLZ help!
Well there are three things needed to run , gas, spark and air ...
We'll assume that airs getting in ... know we need to tell us if you are getting fuel , and spark ...
Old Jul 7, 2007 | 08:10 AM
silvercoupe97
Uber Moderator
...before that, I would take a hammer or rubber mallet and tap the starter on the day(s) it doesn't want to start and if that works.....it's your starter. If it doesn't, BV is right on.
Old Jul 7, 2007 | 02:38 PM
ommar's Avatar
ommar
the problem is that power does not come to the plugs
or even it does not come to the distrubuter, and two mechanics couldnt the problem coz the car started after oneday being in the mechanic shop. do u guys think it is the compputer,. or should i take it to da dearl?
