1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 AVENGER 4CYL 2.0- JERKING WHILE DRIVING
Old Jul 7, 2007 | 08:13 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 97 AVENGER 4CYL 2.0- JERKING WHILE DRIVING
Let us know if the crank angle sensor is your issue. The crank sensor is a common issue with these motors because it's not only in plain view but it's uncovered and in a really hot area. That and magnets and heat don't work well with each other.
Old Jul 21, 2007 | 09:11 PM
army avenger's Avatar
army avenger
How did things work out? Did you change out the sensor and if so did it work, my venge is doing the same exact thing just trying to fix the prob.
Old Jul 22, 2007 | 10:23 PM
99_avenger's Avatar
99_avenger
also try cleaning injector if the cps does not work my had a prob like yours fuel filter had hole thru it causing injectors to clug[sm=gears.gif][sm=nxsmile.gif]
