1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
CPS Replacement ?
Old Jul 23, 2007 | 11:21 PM
etherealwi's Avatar
etherealwi
Default RE: CPS Replacement ?
Turned out to be the disty, igniter must've gone out, but it's running now. And at least I found out Checker's will go 5% lower than Autozone's price out of this, only cost $190. Thanks everyone for your help!
Old Jul 25, 2007 | 05:30 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Good deal bud. Sorry I couldn't answer your last question. You got me on that one, lol.
Old Jul 27, 2007 | 08:19 PM
AvengerInIndiana's Avatar
AvengerInIndiana
Hey Etherealwi, did you ever get an answer on the distributor question? I just replaced mine as part of a neverending repair, and I am wondering if having the wrong one could be part of the problem.
Old Aug 12, 2007 | 02:02 AM
etherealwi's Avatar
etherealwi
Ok now I'm throwing code 43 since I did the distributor! I also replaced the plugs, wires and did the the crank sensor when the problem first happened. I have no idea why I'm throwing this code now. Does anyone have any thoughts on it? And as far as the distributor it appeared there were two different rotors for each distributor so I bought the the one that my old rotor fit on. This it driving me nuts and I still have a exhaust pipe to replace yet but no time with all these other problems. Any help would be greatly apprieciated!
Old Aug 12, 2007 | 07:27 PM
silvercoupe97
Uber Moderator
I would make sure that the distributor that you have is the correct one since there were two to pick from. Did you happen to pull the part number from your old distributor?
If you can return that part do so and get one from NAPA. Their parts are more like OEM than Autozone/Checkers/Pep Boys, etc. I would even find one from a junk yard.
The distributor may not even be the issue with the misfire. It can be a bunch of stuff still. It could be your plugs and wires, gapping, crank/cam sensors, rotor, etc. (all revisited, lol).
I'm pretty sure that you did, but did you disconnect the battery throughout all this? Another thing to make sure is that you replaced all the motor grounds back onto its original locations? The motor is like one big electrical distribution block with sensors + here and there and without proper grounds, those sensors + aren't going to work correctly.
AvengerInIndiana, yes you could have gotten the wrong distributor. Make sure you got one for the 6g73 2.5L. Also check the other things mentioned above.
