1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Internal Antifreeze Leak?
Old Aug 6, 2007 | 07:51 PM
odel0022's Avatar
odel0022
Default Internal Antifreeze Leak?
So recently I have been having some overheating problems, so I serviced it for a new thermostat, radtiator cap, and replaced a worn radiator hose. Also I have a complete radiator flush. About a week after getting all that work done, I checked the res tank and it was a little low so I simply added some more antifreeze just thinkin the radiator had sucked some up. I checked again a week later and it was low once again. I cannot see any visible fluid leaks externally, does this mean that the leak is internal, possibly a head gasket leak?
EDIT: I FOUND 2 LEAKS OF ANTIFREEZE ON GROUND, 1 BELOW RES TANK, and 1 BELOW RAD. CAP.
A just for reference when adding antifreeze/water mixture is it best to do it when the engine is off and cool, or engine off and warm, or engine running?
Old Aug 6, 2007 | 09:26 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Internal Antifreeze Leak?
Tons of things , head gasket leak , cracked head, leaking freeze plugs ...
pop the radiator cap and start up the car and look for bubbles/smoke in the fluid that denotes a head gasket/cracked head
