1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Turbo or supercharger?
Old Aug 13, 2007 | 06:01 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Turbo or supercharger?
I'm not sure of the HP difference, but it shouldn't make enough of a difference just to swap. I would leave the 2.5L in there and turbo that motor. The 2.5 cylinder walls are also thicker than the 3.0L. As you can imagine that there's .5L worth more of metal in the 2.5L. Steve Hernandez (Exile, in the good days) has also stated that previously.
Also, the 6gxx motors are Mitsu
Old Aug 14, 2007 | 05:16 AM
silvercoupe97
Uber Moderator
....when I say "it shouldn't make enough of a difference"...I mean that 40hp isn't a lot when a turbo can be used to compensate for it after the internals have been replaced with forged internals
By no means do I mean that 40 hp is nothing, lol.
Old Aug 14, 2007 | 11:26 AM
Customavenger's Avatar
Customavenger
so if I did do the engine swap and turboed it, It would be approx 40hp more then the stock v6? But the stock engine should hold up better and last a bit longer??
Old Aug 14, 2007 | 12:09 PM
bad venge's Avatar
bad venge
Section Moderator
The 3.0 swap will dyno around 200 hp at the wheels ...I thought the 2.5 was around 160hp at the wheels so you are +40 as it sits no turbo ...
