1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Siphoning Gas
Old Aug 27, 2007 | 07:52 PM
Goose's Avatar
Goose
Default Siphoning Gas
I'm having a hell of a time siphoning the gas outta my 97 Avenger, is there a better way? All I have is a simple siphon, but it only seems to go down so far, feels like its hitting a wall, and all I get is air every time.
Old Aug 27, 2007 | 08:27 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Siphoning Gas
why are you siphoning ???
If you really want to siphon it dry remove the rear seat then remove either the fuel sender or the fuel pump and siphon from there
Old Aug 27, 2007 | 09:15 PM
PappiDread6's Avatar
PappiDread6
U really don't wanna know y? It alwasy worked fine for me just a long tube and pull the fluid out. You could also disconect the fuel filter and hook it up from there.
Old Aug 29, 2007 | 12:13 AM
JokerzVeng's Avatar
JokerzVeng
there is an anti-siphon baffle in most newer tanks...
Old May 24, 2023 | 01:28 AM
bhawk510's Avatar
bhawk510
Default Fuel
bad venge thanks for the info!! mine has sat since 2019 I used your method to get all the old fuel out of my 97 Avenger,I decided to put her back on the road,again thanks again!!
