1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Timing belt problem!
Old Sep 15, 2007 | 03:59 AM
yanickee's Avatar
yanickee
Default Timing belt problem!
Hey,
I'm having timing belt issues! First it's slipping out 2-3mmof the rear cam gear, second teeth are going in weird on the front cam gear, seems like it wants to skip a tooth or two! I am not sure it's normal, but it's just odd! Timing is set, rotated it couple of time, and still on the marks!
I will try to post a video on utube, but right now I am gonna put a better quality video for download! http://rapidshare.com/files/55847554/MOV05632.MPG.html
Old Sep 15, 2007 | 10:26 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Timing belt problem!
linky no worky ....
Old Sep 15, 2007 | 01:56 PM
yanickee's Avatar
yanickee
Here is another one http://bada-bang.com/123.mpg
Thanks!
Old Sep 15, 2007 | 04:38 PM
yanickee's Avatar
yanickee
And here is the utube link http://youtube.com/watch?v=xKV4pLYckmI
Old Sep 15, 2007 | 06:43 PM
bad venge's Avatar
bad venge
Section Moderator
2nd link no worky ...
third link hard to tell could the cam gear be bent ... it looks like it's woobleing but hard to tell
Old Sep 15, 2007 | 09:20 PM
yanickee's Avatar
yanickee
Will the 2.5L cam gears fit 3.0L motor!?
Old Sep 16, 2007 | 10:18 AM
bad venge's Avatar
bad venge
Section Moderator
not sure on that one ...
Old Sep 17, 2007 | 06:05 PM
yanickee's Avatar
yanickee
IS it possible that new timing belt is still needs to be stretched to fit the cam gear perfectly!? I took the new one off and put an old one back on there, and it worked fine! Did not see any problems!
Old Sep 17, 2007 | 06:12 PM
bad venge's Avatar
bad venge
Section Moderator
It's possible ... but the top gear sure looked woobly in the video ... I thought the tensioner was enough to get the belt tight/fitting right
