1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
mitsubishi eclipse SRI
Old Oct 14, 2007 | 06:45 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Default RE: mitsubishi eclipse SRI
yep says 3" aluminum tube so i would assume it was a 3 in filter haha
Old Oct 15, 2007 | 06:27 PM
dynamiteplaya3
could this intake make my exhaust sound better? just curious
Old Oct 15, 2007 | 06:55 PM
bad venge's Avatar
bad venge
Section Moderator
It'll give more noise under the hood ... not much difference in the exhaust note
Old Oct 20, 2007 | 07:50 AM
dynamiteplaya3
ok so im getting my intake in today and am a little confused.... it sems pretty easy to install but it says it will not come with the installation directions. and there are a few silver things to hold it in place (im guessing) now is there a certain place for these or are they even needed heres a pic of what im talking about.
Old Oct 20, 2007 | 09:41 PM
bad venge's Avatar
bad venge
Section Moderator
the silver strapping is meant to support the far end some mount it to the black part where the stock box went to others bend it to mount on the battery plate
Old Oct 21, 2007 | 11:39 AM
dynamiteplaya3
ok well i installed it yesterday and i can def. tell a diff in torque and sum horsepower. buti did have to make a few mods to sum things lol... first of all when i went to put it in the tube kept hitting the windshield washer reservoir. so basically i had to take a hammar to it to bend the plastic in a little bit and no prob. it fit in fine. but then another issue came up lol. now where the tube bends up by the throttle body it was too wide and it kept running into the battery so i had to take the battery completely out and and put it back on no prob. but then the battery wouldnt go back in lol. so basically i spent an hour just trying to figure out how to fit the battery back in the car lol so basically i tilted the battery sideways and it all fits in ok... it looks a little weird but it still works lol. but theres no brace holding the battery in hahaha. basically my intake tube is all thats holding it it. but its all pretty crammed in there so i dont think anything will move.
but hey im just glad it works. and it also makes the engine sound pretty bad ***
Old Oct 21, 2007 | 03:11 PM
bad venge's Avatar
bad venge
Section Moderator
some people trim about 1/4 to 1/2" off the end where the intake conects to the TB to allow room for the battery hold down ...
Old Oct 21, 2007 | 06:06 PM
dynamiteplaya3
well ifi can find a battery small enough ill probably just buy a smaller battery all i need is about an inch and it will all fit in perfect. and ill just find another way to hold down the battery.
Old Oct 21, 2007 | 07:46 PM
bad venge's Avatar
bad venge
Section Moderator
be sure to do that asap .... several have had the battery short to the hood and cause major damage ....
Old Oct 22, 2007 | 03:48 PM
dynamiteplaya3
what kind of damage do u mean.
