1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Kind of a dumb question, '97 avenger
Old Oct 12, 2007 | 08:33 PM
Colro's Avatar
Colro
Default Kind of a dumb question, '97 avenger
I've recently bought a 97 avenger, but the rear-right turn signal is burned out. I've got a new bulb, but I can't for the life of me figure out how to get to the old bulb to change it. I've got the screws out of the panel in the trunk that leads to it, but Istill can't see how I can get it out. Anyone else with a 97 know how?
Old Oct 12, 2007 | 09:04 PM
Haze99avenger's Avatar
Haze99avenger
Default RE: Kind of a dumb question, '97 avenger
hmmm... if the lights are the same as the 99' then there should be three or four bolts that hold the light in place, i took the bolts off and it popped it off.... if im remebering correctly... i will take pictures tomorrow and post them and give you a step to step inless your question is answered already by then...
Old Oct 12, 2007 | 09:46 PM
bad venge's Avatar
bad venge
Section Moderator
Pull down the carpet , remove the 10mm nuts push out on the "bolts the tail light comes off replace bulb reverse procedure ...
or take it to autozone they'll do it ...
Old Oct 13, 2007 | 11:59 AM
Haze99avenger
ok i thought i was rembering right.... i had to do it for my lights too
