1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
What are the pros and cons on adding a second exhaust pipe?
Old Oct 17, 2007 | 08:54 PM
SpeedDemon3000's Avatar
SpeedDemon3000
Default What are the pros and cons on adding a second exhaust pipe?
One of my buddies suggested that I add another second exhaust pipe to the Avenger. Does anybody have any opinions about that?
And for those who have a second exhaust pipe installed, which mechanic shops do you recommend to havethe second pipeinstalled?
Old Oct 17, 2007 | 09:13 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: What are the pros and cons on adding a second exhaust pipe?
are you wanting to run DUAL exhausts ???Or just two tailpipes in the rear??? I4 or V6 ???
Old Oct 18, 2007 | 11:12 AM
SpeedDemon3000
Dual exhausts.
Old Oct 18, 2007 | 12:29 PM
PappiDread6's Avatar
PappiDread6
Alot of ppl want to do duals because its looks as tho that where suppose to have them. With the N/A I4 its a waste of money because you'll loose alot of back pressure causin a lose in power, thats y its best to run 2 1/5' cat back exhaust. Performance headers will raise your torque tho but keep the stock cat till you get turbo'd. With the V6 you can run duals but I think you'll have to do it with stock pipes which I think is 2 1/4'.
Old Oct 18, 2007 | 05:53 PM
bad venge's Avatar
bad venge
Section Moderator
Since we been thru this before : https://dodgeforum.com/m_787509/tm.htm
