1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
02 sensor removal
Old Oct 18, 2007 | 04:07 PM
95_dodge_avenger's Avatar
95_dodge_avenger
Default 02 sensor removal
on my 2.0 both o2 sensors are factory typenever replaced till now, only problem is they are on so tight i caint get them to turn with the o2 sensor and a rachet, any sugestions?
Old Oct 18, 2007 | 04:34 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Default RE: 02 sensor removal
Bang the **** outa it until it gets loose.. hammar and a rachet should do it. or if its realllly rusted on there just get sum liquid wrench (and penetrating oil) and spray sum on there and it should break up all the rust buildup and should loosen. i had the same prob. recently and i was tugging on it so hard i thought the car was going to fall off the jack on top of me.but i just got sum pen. oil and she still required a lil work and eventually worked itself loose
Old Oct 18, 2007 | 04:39 PM
95_dodge_avenger
kool, i was doin a chrysler the other day, same situation, but i ended up breaking the sensor in have, lol, i thought it was awsome, my girl was pissed though, so i toke it to a muffler shop, they charged 65 dollars just to remove it
Old Oct 18, 2007 | 05:49 PM
bad venge's Avatar
bad venge
Section Moderator
Sometimes heating it with a propane torch will help break it loose too , just be careful if you have it soaked in penatrating oil ...
Old Oct 18, 2007 | 11:22 PM
95_dodge_avenger
yea, the oil, and torch didnt help, would a impact do the job?
Old Oct 19, 2007 | 10:34 AM
bad venge's Avatar
bad venge
Section Moderator
likely to snap it off in the bung ...
Old Oct 19, 2007 | 11:40 AM
95_dodge_avenger
bung?
Old Oct 19, 2007 | 12:20 PM
bad venge's Avatar
bad venge
Section Moderator
Bung= The mounting on the pipe
Old Oct 19, 2007 | 01:22 PM
95_dodge_avenger
so, it wont be a good idea to use a impact?
