1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
eratic idling
Old Oct 22, 2007 | 09:04 AM
offduty97's Avatar
offduty97
Default eratic idling
I need help! I just purchased a 1996 avenger es with a 2.0 motor. Last night I was performing basic maintenace on it. I replaced the PCV valve, spark plugs, and wires and when I started it up it is idling a little rough. It is not giving me a check engine light and it is not to the point that itwon't drive but I can here and see it on the tach that it is just a little off. I checked the valve (good) and the wires all are tight and connected. Could it be the brand of spark plugs I used ? I put Autolite platinum #AP3923. I know I have heard that some cars are picky about plugs I just don't understand how it could be missing with all new parts? Like I said I am new to this forum so be nice and I look forward to all of the information that is available here. Any other things that I should look for with this car, I already know about the ball joint recall and I am contacting the dealership this morning. Thanks in advance.
Old Oct 22, 2007 | 07:02 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: eratic idling
I'dcheck the IAC motor they tend to gum up and cause erratic idle ....
Old Oct 22, 2007 | 07:14 PM
PappiDread6's Avatar
PappiDread6
I was inddling at 1,200rpms I check alldata we suppose 2b around 8 so I did my sparkplugs and wires and she had trouble idling it would alwasy fluctuate like I was messin with the A/C button. But now its back to normal. I was thinking it might be the the were cheap plugs or prolly my O2 sensor haven't changed that yet.
BV- What is IAC Intake Air Cleaner, Idle Air Control???
Old Oct 22, 2007 | 08:05 PM
bad venge's Avatar
bad venge
Section Moderator
Idle Air Control ... located on the TB ...
Old Oct 23, 2007 | 01:41 PM
PappiDread6
Is it that lil rubber tube that runs off the TB? I know its kinda messed up the rubber on it is worn I want to replace the line but I can't seem to follow it. But if I take it off it idles higher if I leave it on it kinda studders then goes back to normal
Old Oct 23, 2007 | 08:05 PM
bad venge's Avatar
bad venge
Section Moderator
It's actually inside the TB ....
