1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
hydrolic timing tensioner
Old Oct 28, 2007 | 10:22 AM
95_dodge_avenger's Avatar
95_dodge_avenger
Default hydrolic timing tensioner
how do u get the plunger on the tensioner back in to reinstall it? the book says use a vice, but i dont have a vice
Old Oct 28, 2007 | 10:54 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: hydrolic timing tensioner
I viced mine in , either borrow one or do you have a big "C clamp" possibly be able to get that on and compress it ...I used a large zip tie to to hold mine then clipped it when installed
Old Oct 28, 2007 | 07:52 PM
noel's Avatar
noel
I have used a vice twice, and a C-clamp once. vice was certainly much easier. Not sure which engine you have. On the 2.0 L4, there is a pin hole on the side that goes all the way through the bloack and shaft.I sacrificed an allen wrench- put through the pin hole to hold the shaft compresed while you install. Although it sounds like the zip tie works perfectly well too - andwon't ruin your allen wrench
Old Oct 28, 2007 | 08:20 PM
95_dodge_avenger
i have the 2.0, does anyone know the cheapst price to transfer a title for a vehicle in texas?
