1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
another dead avenger
Old Dec 13, 2007 | 04:19 PM
danger avenger's Avatar
danger avenger
Default RE: another dead avenger
the humming is coming from the pcm ive checked twice is it supposed to make a noise?
Old Dec 13, 2007 | 06:13 PM
danger avenger
ok i think i've solved 80 % of my problem i finally tore everything apart and narrowed it down to the starter i think ( when i try to turn it over it jus trys but it sounds like a dead battery but its not and after several tries the starter is just burning up and the ground wire to the battery post well lets say i cant touch it?) can someone tell me if this sounds like the starter? thanks a bunch!
Old Dec 13, 2007 | 08:36 PM
bad venge's Avatar
bad venge
Section Moderator
I'm thinking the motor is froze up .... the starter can not move it so it ulls excessive current causing the hot wire ...
I'd try to remove the starter , and secure it try to turn it ... if it spins freely then it's likely the motor
Old Feb 20, 2008 | 01:26 PM
danger avenger
ok im back. here are the parts i have replaced and checked. replaced( plugs,wires,relays,pcm,tcm,fuses.) Checked and are good. (fuel pump, starter,ingnition, coil pack and cam sensor.) havent done anything with the crank sensor yet..car is still non running from what you said earlier that the motor may be froze up? i dont know how that would work all pulleys including the cams and crank .. when i turn it over its wanting to spin but its a slow hard spin any more suggestions? thanks
Old Feb 20, 2008 | 02:01 PM
bad venge's Avatar
bad venge
Section Moderator
Have you tried a compression check on the cylinders ??? Might have broke a piston
Old Feb 20, 2008 | 07:04 PM
yanickee's Avatar
yanickee
Man I hope it's not a piston! But I would drain the oil and see if there is anything unusual
Old Feb 20, 2008 | 08:40 PM
PappiDread6's Avatar
PappiDread6
Yo danjah you try spinning the crank by hand.
