95 avenger has bad gas mileage, clicks, and rear speakers dont work...
#32
#33
RE: 95 avenger has bad gas mileage, clicks, and rear speackers dont work...
ORIGINAL: TheZephire
so would a new amp fix this?
the same thing happend to me a couple months ago..i replaced the fuse..and it started working fine again..i say try that
and about the mpg yeah theres somthing wrong with your car..i have a 96 bring which is the same as the avenger and i get about 275 to the tank...
#34
#36
bad venge,
What is the difference between all these oxygen sensors(downstream/upstream, rear/front)? I understand they are located in different places, but is it the same part with different cable lenths? I have a gas mileage problem and wanna try the O2 sensor trick. Can i just buy universal and play with it?
#37
I've heard that the cheap ones arent tthat good some say the car wont run with then some say they are fine. I would recomend buying the oem bosh type so you dont have to splice wires and crap. and the up stream and down stream i am not to sure i am guessing that upstream is the one that is right behind your intake plenium "front" and the downstream is down stream "back" from that one. the front one i also beleave is the one that messes with your MPG the most. I only get like around 250 to 275 MPG when i baby foot her.. hope this helps
Joe
Joe
#39
