1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1998 Avenger
Old Dec 17, 2007 | 06:42 PM
JerryA1982's Avatar
JerryA1982
Default 1998 Avenger
I left the key on my daughters car. Battery drained. Hooked up the charger forgot the key as still on. Anyhow, turned the key to off charged the battery, Drove it to school went to leave and the car won't start. Also prior to that I just filled with gas.
Old Dec 17, 2007 | 08:53 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 1998 Avenger
Recharge the battery and havethe battery/charging systemtested at autozone ect(free) .... possibly totally draining it killed the battery ...
Old Dec 19, 2007 | 07:20 PM
JerryA1982's Avatar
JerryA1982
Thank for your reply. I was kinda short on my post. But....The batter is fully charged and the car turns over fine, just won't fire. My ultimate question was that when I put the charger on the battery the key was on and I was wondering with the key left on if I damaged something? I did pull a spark plug out and there is no fire. Seems pretty coincidental. Sorry for all the bad spelling.
Old Dec 19, 2007 | 08:45 PM
bad venge's Avatar
bad venge
Section Moderator
up in the top of the forum there is a post on relays check them first ...
Old Dec 20, 2007 | 08:11 PM
JerryA1982's Avatar
JerryA1982
Thank you for your help.
Replaced the ASD relay still a no go on starting. If it helps out this is 1998 2.5 engine.
Old Dec 20, 2007 | 08:17 PM
bad venge's Avatar
bad venge
Section Moderator
Do you hear the fuel pump kick on ???
Old Dec 21, 2007 | 08:50 PM
JerryA1982's Avatar
JerryA1982
Yes it does kick on. I pulled a spark plug and checked for spark. None! So now what? Did I fry the computer? Thank you for your help on this.
Old Dec 22, 2007 | 12:59 AM
TheZephire's Avatar
TheZephire
my cuz has a 1997 dodge avenger, same thing happend, the crank positioning sensor was gone.
Old Dec 22, 2007 | 10:06 AM
bad venge's Avatar
bad venge
Section Moderator
yes CPS testing procedure on top ...
Old Dec 26, 2007 | 05:33 PM
JerryA1982's Avatar
JerryA1982
bad venge, thank you for help on this issue. Now one more thing and please do not take this the wrong way. I read in a previous post somewhere on this forum that the 98 vengers do not have a crank sensor.
I did read the post on the top of the forum about the cps.
