1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
strut selection...
Old Dec 22, 2007 | 02:05 PM
drumma's Avatar
drumma
Default strut selection...
ok i'm lowering my venge. i have KYB AGX struts on eibach springs onthe back that i got really cheep. but i need struts for the front. i have the spring already but wanted to know the differnce between the KYB GR-2's and the AGX's theres a big differnce in price but wat else?
Old Dec 22, 2007 | 04:29 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: strut selection...
If you read my lowering sticky it's all covered ...
but the agx's are adjustable and stiffer then the gr2's the gr2's are basically oem replacement they do not hold up well to lowered suspensions ...
Old Dec 22, 2007 | 07:37 PM
drumma's Avatar
drumma
hey if i take my carin for alignment will they know how to help me get the right size bolts and washers for a chamber kit?
Old Dec 22, 2007 | 09:04 PM
bad venge's Avatar
bad venge
Section Moderator
The formula is 1/4" of spacers per degree of correction ... 3 degrees =3/4" of spacers and stock bolt length+ 3/4"
https://dodgeforum.com/m_1098131/tm.htm
Old Dec 23, 2007 | 06:26 PM
drumma's Avatar
drumma
ok sweet, thanks for all the info up top..
