1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rev's high when starting
Old Jan 1, 2008 | 10:23 AM
marko69's Avatar
marko69
Default Rev's high when starting
When I start the car, it always revs really high for about 2 seconds, goes up to about 2k rpm's then comes back to 800 or so, then it's fine. I've cleaned out the throttle body and installed a new IAC but no help.I checked the air temp sensor and it reads 10kohms @75deg but I don't know what it should read. (AlsoIt also acts like it wants to stall sometimes at a red light. If I put it in neutral then it's ok. Probably not related, but I thought I'd add that.)
Old Jan 1, 2008 | 12:12 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Rev's high when starting
I'd check the EGR next ... I'm assuming no CEL ...
Old Jan 1, 2008 | 10:29 PM
marko69's Avatar
marko69
Ok, thanks, I'll check that out. (right, no codes)
Old Jan 2, 2008 | 08:18 AM
PappiDread6's Avatar
PappiDread6
What size motor? I have the I4, and had the same prob but it was the rubberhose running off my intake that ran across the fire wall.
Old Jan 5, 2008 | 11:46 PM
marko69's Avatar
marko69
I have a 2.0 liter. I'll have to take a look at the hoses.
I was going toget a new egr valvebut I'llsee if I can find that hose you mean and check that first.
Old Jan 6, 2008 | 10:29 AM
bad venge's Avatar
bad venge
Section Moderator
the hose feeds the IAC
