1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Avenger oxygen sensor error
Old Dec 7, 2004 | 11:15 PM
budds25's Avatar
budds25
Default Avenger oxygen sensor error
I have 97 Dodge Avenger with the check engine light on. I had it hooked up to a code reader and it read an oxygen sensor error. I replaced both sensors with new OE sensors and disconnected the battery for 15 min. The light went off and came back on after 2 start ups and has remained on. It is still giving an oxygen sensor error code. Anyone know what the problem is?
Old Dec 8, 2004 | 03:37 AM
blink182515's Avatar
blink182515
Default RE: Avenger oxygen sensor error
Have you added anything that isn't stock or OEM? Like intake, headers, etc...
those things can cause problems like that.
Old Dec 8, 2004 | 12:21 PM
budds25's Avatar
budds25
No, everything is stock.
Old Jan 22, 2005 | 01:54 AM
avengeres's Avatar
avengeres
MINE DID THAT ONCE AND IT WAS BECAUSE THE GAS CAP WASN'T SCREWED ON TIGHT ENOUGH.
Old Jan 27, 2005 | 09:21 PM
DomestiqueImport's Avatar
DomestiqueImport
I had the same error, plus a few others when I ODBII'ed it. Went to Dodge Dealership, recet ECU, cleared that right up.
