1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Throttle Cable
Old Jan 31, 2008 | 10:26 AM
akaaceman's Avatar
akaaceman
Default Throttle Cable
Does anyone know where to find a replacement for the cable that runs from the throttle body to the cruise control box on a V6? I've tried numerous methods to get a smooth response on my throttle but it seems like I have to replace that cable. Thanks!
Old Jan 31, 2008 | 10:37 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Throttle Cable
I lubed mine with a motorcycle cable power luber really smoothed things out ...
Old Jan 31, 2008 | 11:15 AM
akaaceman's Avatar
akaaceman
If you don't mind my asking, where did you find that luber and how expensive was it?
Old Jan 31, 2008 | 12:18 PM
bad venge's Avatar
bad venge
Section Moderator
Motorcycle shop , under $20 it has a block that attaches to one end of the cable then the spray can of lube hooks into it you push the button and it flushes thru the cable ... I use WD40 to flush the dirt grime out (same spray can hook up tube) then the luber after it
