outter tie rod
im trying to replace the outer tie rod, i think i may have to replace the inner as well b/c there is still movement in the rod itself. anyways i took the old one off. had to use a puller to get it out. i suppose its a press fit? when install the new one, do i need to push it all the way down inside to bore hole? or just put the nut on and torque to 55 ft lbs? it book really doesnt tell. thanks.
