1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
starting proplem
Old Feb 19, 2008 | 05:40 PM
98venge's Avatar
98venge
Default starting proplem
earlyer to day my 98 2.5l automatic venge wouldnt turn over when i turned the key there was battery power and i heard a clicking in by the radio and under the hood when i tryed to start it .does any one have an idea of what it could be thanks
Old Feb 19, 2008 | 05:50 PM
yanickee's Avatar
yanickee
Default RE: starting proplem
Check you battery, you might have enough juice to power the radio, but not enough to crank the starter!
Old Feb 19, 2008 | 07:24 PM
98venge's Avatar
98venge
i got enough juice it finally started after i ripped half my center console out lookin for some kind of netrual saftey switch could that be the prop and were is it?
Old Feb 19, 2008 | 07:40 PM
yanickee's Avatar
yanickee
http://forum.doityourself.com/showthread.php?t=217791
Check it out. Might help!
Old Feb 19, 2008 | 08:08 PM
bad venge's Avatar
bad venge
Section Moderator
neutral safety is under hood on the tranny beside the reverse light switch ...
If I was a betting man I'd say relay trouble or CPS trouble
Old Feb 19, 2008 | 08:49 PM
98venge's Avatar
98venge
whats cps? thanks
Old Feb 19, 2008 | 08:52 PM
yanickee's Avatar
yanickee
CPS is Crankshaft Position Sensor
Old Feb 19, 2008 | 09:03 PM
bad venge's Avatar
bad venge
Section Moderator
CPS testing procedure in the stickies above as is the relay info
