1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help!
Old Feb 20, 2008 | 06:05 PM
The Harlot's Avatar
The Harlot
Default Help!
Have a 97 and got some bad gas with water in it. Started chugging upon exceleration. Put dry gas in it and it doesnt do it as much. Have gone through 2 full tanks of gas. When i excelerate my cel blinks at me and when it stops chugging it stops blinking and stays lite. Any ideas?
Old Feb 20, 2008 | 06:27 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Help!
I'd change out the fuel filter ... The bad gas might have had dirt/rust in it as well
Old Feb 20, 2008 | 07:45 PM
Sroufe7's Avatar
Sroufe7
Default RE: Help!
Blinking CEL usually means a miss fire.
Check your plugs and see what they look like.
Have you done a tuneup lately?
Old Feb 20, 2008 | 08:42 PM
PappiDread6's Avatar
PappiDread6
Default RE: Help!
Hopefully it didn't mess up your fuel pump. I agree with sroufe7 about the tune up.
Old Feb 21, 2008 | 05:02 PM
The Harlot's Avatar
The Harlot
Default RE: Help!
Thank you for your responses. Those are the first things i thought about but would it also mess with my o2 sensor?
Old Feb 21, 2008 | 09:04 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Help!
If it messed with the O2 sensors it shouldhave a solid Check engine light
Old Feb 22, 2008 | 05:30 PM
The Harlot's Avatar
The Harlot
Default RE: Help!
it does until it chugs, then it blinks.
Old Feb 22, 2008 | 05:35 PM
Sroufe7's Avatar
Sroufe7
Default RE: Help!
get a code number/s
Old Feb 22, 2008 | 05:51 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Help!
Go to autozone ect and have the codes scanned ... write them down and tell us the codes listed
