1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
99 Avenger door speaker replacement help
Old Feb 21, 2008 | 08:58 PM
99Avenger25's Avatar
99Avenger25
Default 99 Avenger door speaker replacement help
I need to replace the door speakers in my 99 Avenger. Can anyone help me with info on getting the door panel off?
I'm not sure if I need to remove the whole panel, or just the speaker cover. Thanks for any help
Old Feb 21, 2008 | 09:13 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 99 Avenger door speaker replacement help
entire door panel has to come off ...
Screws in the door handle cup,in the handle pull under plastic cover might be one other on the bottom...
Pull to remove ...
Old Mar 1, 2008 | 01:53 PM
98venge's Avatar
98venge
i have mine off as i speak i just used a screwdriver to pry of the cover in front of the speaker didnt have to take off the entire panel
Old Mar 1, 2008 | 02:31 PM
bad venge's Avatar
bad venge
Section Moderator
You also RUINED the door panel [:@] Those grills are plastic welded on and you damaged them doing it that way ... Have fun repairing the damage
