1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Trans on a 95 Avenger 2.5
Old Feb 16, 2008 | 07:01 PM
slinky1202's Avatar
slinky1202
Default Trans on a 95 Avenger 2.5
I have a weird problem with my transmission. It will shift in all gears but I can only go 65 miles an hour tops. It used to go up to 100 hundred with no problem. Is it possible that my overdrive gear is gone?
Old Feb 16, 2008 | 07:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Trans on a 95 Avenger 2.5
check your back up lights .... no lights = blown fuse blown fuse= no overdrive
Old Feb 16, 2008 | 11:39 PM
PappiDread6's Avatar
PappiDread6
Sounds like you lost you final drive gear. What color is your trans fluid and how many miles. My girls galant has the same prob shifts fine but red lines at 70mph fluid is black. Also when you hit the overdrive button it goes into neutral.
Old Feb 17, 2008 | 11:14 AM
slinky1202's Avatar
slinky1202
Great. I will check and see if it is the fuse. If not then it must be a bad gear in the transmission. I do have another question. My car has a odb II connector but does not talk to the computer. It also has a white one that I cannot find a tool to connect to it? I would like to pull the codes out of the computer? Any ideas?
Thanks
Old Feb 17, 2008 | 11:46 AM
bad venge's Avatar
bad venge
Section Moderator
Take it to autozone....they have the right connectors to pull codes ...Do you have a Check Engine Light on ???
Old Feb 17, 2008 | 12:26 PM
slinky1202's Avatar
slinky1202
No check engine light. I just wanted to find the connector device so I could purchase a scan tool for it. The backlight fuse is good. So it sounds like my overdrive gear is gone. Which means the rest of the trans is next to follow.
Thanks for the help.
Old Feb 17, 2008 | 05:57 PM
slinky1202's Avatar
slinky1202
Default ECU connetors?
bad venge in the pic you can see the black odb II connetor but what is the white? I have my own odb II scan tool and it does not communicate with the ECU. Now my 2000 avenger odb II connector is the same and it works just fine. What is different between the 95 and 2k model?
Old Feb 18, 2008 | 10:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: ECU connetors?
1995 and 1996 Avengers need to have a two pig tail OBD 2 to talk to the car, because its has mits electronics. But I don't your is a transmission, but maybe exhaust. You said the trans shifts thru all gears, but you didn't say anything about slippng. So you could have a cat starting to plug up on you.
Old Feb 19, 2008 | 05:32 PM
slinky1202's Avatar
slinky1202
Default RE: ECU connectors?
Thanks I will this weekend check the exhaust out and see if it is plugged. I did not think of that. No transmission is not slipping just wont go above 65 mph. I will give this a try.
slinky1202
Old Mar 2, 2008 | 08:38 PM
slinky1202's Avatar
slinky1202
Changing out the cat did the job. Thanks for the heads up. I will never forget that.
TY
