1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Fan switch
Old Mar 13, 2008 | 12:24 PM
  #21
bad venge's Avatar
bad venge
Section Moderator
Default RE: Fan switch
Things that affect temperature :
Thermostat
Radiator cap
Proper coolant
Water pump
I'd replace the first two , then flush radiator and add new coolant
Old Mar 13, 2008 | 09:02 PM
  #22
Klikzzz's Avatar
Klikzzz
the sensor that turns on the fan is the same as the coolant sensor? where is it located?
the thermostat is changed and the coolant flushed too, not sure abt the water pump but no leaks anywhere at all though.
Old Mar 13, 2008 | 10:09 PM
  #23
bad venge's Avatar
bad venge
Section Moderator
The coolant sensor = Temp gauge sensor .... I'm assuming it's working OK but if you really feel the need to change it go ahead ...
Old Mar 14, 2008 | 02:45 PM
  #24
Klikzzz's Avatar
Klikzzz
lets c.. thts the only thing left to change before i get onto water pump n all....
Old Mar 17, 2008 | 07:29 PM
  #25
bjpomeroy's Avatar
bjpomeroy
Just a shot in the dark here. Are you having to add coolant frequently? I have a leak that I recently found to be a leaking water pump.If not have you burped your radiator? My guage does the same thing yours does but usually when I am running low on coolant. Food for thought.
Old Mar 19, 2008 | 08:52 AM
  #26
Klikzzz's Avatar
Klikzzz
no my coolant is fine.... burped the rad too.... i just changed the sensor too... seems a lot better now.. but im ready to do the t-belt and water pump next ....
Old Apr 9, 2008 | 09:30 AM
  #27
Klikzzz's Avatar
Klikzzz
ok just wondering.... now the guage just goes up when im idling or at a stop... sign of weak water pump?
Old Apr 14, 2008 | 10:18 AM
  #28
Klikzzz's Avatar
Klikzzz
no help on this?
Old Apr 14, 2008 | 10:27 AM
  #29
bad venge's Avatar
bad venge
Section Moderator
how far up does it go ...whats the outside temp...slight movement normal 1/4 gauge not
Old Apr 14, 2008 | 11:07 AM
  #30
Klikzzz's Avatar
Klikzzz
up till the markings towards H... not over tht.. thts when the fan kicks and it comes down... guessin its normal...
