1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 transmission
Old Feb 27, 2008 | 06:13 AM
gboro21's Avatar
gboro21
Default 95 transmission
in limp mode on a 95 avenger. transmission is a jasper, I called their service dept and they said replace input and output sensors it should run fine. I did this, bought new sensors from dodge dealer and as soon as I replaced them the car would not start at all. any ideas? drove the car 100 feet 2 mins prior to swapping out sensors so it was working. 30 mins later...nothing
Old Feb 27, 2008 | 02:06 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 transmission
check if you unplugged anything ...then relays cps
