1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Cold Air Intakes?
Old Mar 17, 2008 | 01:03 PM
blackvenger's Avatar
blackvenger
Default RE: Cold Air Intakes?
i got a questoin may sound stupid but whatever... isnt it true that since our cars, or my 95 avebger anyways, dont have a MAF sensor they opperate on speed density... so basiclay the pcm doesnt know you are pulling in more/denser air, and unless you reprogram your pcm it is almost pointless?
Old Mar 17, 2008 | 02:11 PM
bad venge's Avatar
bad venge
Section Moderator
It has sensors that figures incoming air TEMP and uses the O2 sensors to adjust to the proper ratio with the fuel it LEARNS that you have an intake
Old Mar 17, 2008 | 08:50 PM
dynamiteplaya3's Avatar
dynamiteplaya3
could this cause ur o2 censors to get confused cause my check engine light is on and the code is the o2 sensors andi just replaced them??
Old Mar 17, 2008 | 08:53 PM
bad venge's Avatar
bad venge
Section Moderator
shouldn't ... unplug the battery for ten minutes then reconnect it and see if codes go away
Old Mar 29, 2008 | 02:15 AM
account1's Avatar
account1
So i went to many performance shops and all of them searched for K&N and AEM intakes and both of those brands DONT make intakes for 95 avenger ES's anymore. So i was thinking weapon R, but i talked to one of my car buddies and he said that weapon R isnt the best way to go but if theres nothing else to settle for it. Straight up what do you think is the best intake that i should get is? (since K&N and AEM dont make them)
Old Mar 29, 2008 | 07:13 AM
Goose's Avatar
Goose
I have a weapon R on my 97 2.5, and its great. To hell with the idea of a no name intake, you ALWAYS get what you pay for. I love mine though, gives a little extra power and sounds great.
Old Mar 29, 2008 | 08:54 AM
Sroufe7's Avatar
Sroufe7
http://catalog.disturbingmotorsports...;cPath=1_2_6_7
