Lower Control Arm Bolt Help!
Im trying to change the halfshaft on my 96 Avenger and Im having a hell of a time getting the bolt out of the lower control arm. Anyone have any suggestions outside of WD-40 and a hammer? Thanks
I had same problem trying to change my curved arms under there. i used a cheater pipe put the wrench on it and put the pipe over it an poof it came off in about 4 secs. carefull takent he balljoint off with the seperator the other balljoint is right there by it and you may hit the other one an tear it up. i almost did
Joe
Joe
I think I was too vauge n the description of my problem. Im not trying to remove the control arm. Im trying to remove the bolt that runs thru the A fork and bolts thru the straight lower control arm. I got the nut off of the bolt but it will not come loose from the rubber grommet in the arm. Hammering and lube has moved it a milimeter but thats it.
