1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
fusible links?
Old Mar 19, 2008 | 08:54 AM
Klikzzz's Avatar
Klikzzz
Default fusible links?
just a dumb question... but what are the things over the fusible links under the hood? im not talking about the fuses... but the small black boxes ? relays? if so, can i just pull and replace them? im guessing my Horn 'relay' is bad...
Old Mar 19, 2008 | 10:26 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: fusible links?
Pictures help since the description isn't the best ... There are relays in the underhood fuse block , it TELLS what they are on the top of the box
Old Mar 19, 2008 | 10:47 AM
Klikzzz's Avatar
Klikzzz
dont have a cam handy for pictures... but yes its in the fuse box under the hood.... and yes they do say what they are on the top... so those are just relays? what do i ask the dealership for? just 12v relays for the horn?
Old Mar 19, 2008 | 11:59 AM
bad venge's Avatar
bad venge
Section Moderator
most take a 30 amp boshe style relay any parts store has them even radio scrap
