1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Misc Parts
Old Mar 25, 2008 | 09:12 PM
73dart's Avatar
73dart
Default RE: Misc Parts
I rebuilt mine for around $800 thats witout changing the pistons and built to stock.
Old Mar 25, 2008 | 10:15 PM
darkestxxnight's Avatar
darkestxxnight
pistons and piston rings are the expensive part
Old Mar 26, 2008 | 06:16 AM
PappiDread6's Avatar
PappiDread6
I asked around a while back and it was $300. I just wanted to see if that was in the right price range. I thought about doing it myself but don't have the down time, and dobt I have all the tools
Old Mar 26, 2008 | 06:32 AM
73dart's Avatar
73dart
I dont rember indivual prices but I do rember I almost fell out my chair when they told me how much the rings were. I had to rebuild mine I only had 30lbs of compression on the #4 cylinder and was only getting 24 mpg. Now Im getting 30-35 depending on how I drive. Also I am posting the pics of the motor I have for sell as well.
Old Mar 26, 2008 | 06:35 AM
73dart's Avatar
73dart
More Pics of motor.
Old Mar 26, 2008 | 01:53 PM
darkestxxnight
lol you're going to still have the downtime if you pay a shop to do it. you think they'll be done in an hour? and you'll pay out the *** having them do it, you might as well just buy a crate motor then.
pistons $500+
rods $350+
piston rings $100+
oil pump $100+
main and rod bearings $100+
complete gasket set $175+
valve spring & retainer $300+
valves $200+
rocker arms $150+
lifters $100+
waterpump, timing belt, timing idler pullies $130+
fluids, belts, hoses, and misc $300+
machine work $200+
you're at over $2700 in parts/machine work. not even including the labor fees a shop would charge you.
Old Mar 26, 2008 | 01:55 PM
darkestxxnight
ORIGINAL: PappiDread6
lol if you can rebuild your motor for $300 i'll pay you $500 to do mine..
Old Mar 26, 2008 | 09:10 PM
73dart's Avatar
73dart
We replaced #4 piston, piston rings, rod and main bearings, cam pos sensor, all the gaskets, water pump, and timing belt on the bottom end. That cost me $600. On the head the machine shop shecked it for cracks, did a valve job, replaced all the valve seals, the exaust valve guides, and remove a broke stud, That cost me $258. We replaced all the bearings and seals in the transmission and that cost $180. It is a different car now and I am very happy with it.
Old Mar 27, 2008 | 08:30 AM
PappiDread6
ORIGINAL: darkestxxnight
LOL!! Naw that was just the heads. I work in a shop so I can pull them and reinstall them myself. I wish a rebuild wasthat cheap. My motor washydrolocked back in 2000 the previous owner had the bottom end repaired gave me the receipt too.Details as of 5/5/00 This has what been changed:
Short Block - $2,925
Thermostat & Gasket - $14.50
Air Filter - $29.44
Upper Rod Hose - $16.56
Spark Plugs - $14
Lower Rod Hose - $14.82
ALT Belt - $14
Coolant - $15
A/C P/S Belt - $ 24.40
Oil & Filter - $10
Timing Belt - $80.10
Freon & Oil - $45
Clutch Kit - $350
Head Bolts - $17.80
Water Pump - $78.26
2 Cam Seals - $ 11.20
Upper Gasket Kit - $115
Crank Seal - $ 5.35
Lower Gasket Kit - $57.50
Total - $3837.93
Old Apr 2, 2008 | 09:00 PM
73dart's Avatar
73dart
i'm in WI. so if you could find out the condition and let me know we can go from there. just let me know.
Got it apart tonight and have some new pics for you. The motor turns freely and looked good inside crosshatch is still clearly visible.
