1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
car's dead somebody help figure out why
Old Mar 27, 2008 | 10:36 PM
slakr's Avatar
slakr
Default car's dead somebody help figure out why
ok so here's my problem. i have a 95 avenger 2.0L 5-speed. last week it siezed on me and after i had it towed home the first thing i did was pull the plug wires out and the #4 plug well was full of oil. i pulled the valve cover off to find that the plug rings had failed so i replaced them. while i had the cover off i looked at the internals and they looked to be in excellent condition considering the mileage. while i still had the cover off i took the time to check the timing belt which was in mint condition, i checked the plugs, wires, and distributor and they all checked out fine. the car has a new battery and the starter tested well and the car has spark...... problem is that the engine will only turn over a couple times and VERY VERY slowly and obviously won't start. so to recap all the internals seem to be fine, new battery with spark and starter's fine but non running engine. anyone have any ideas? anything would be greatly appreciated. thanks, brandon
Old Mar 28, 2008 | 02:41 AM
darkestxxnight's Avatar
darkestxxnight
Default RE: car's dead somebody help figure out why
how did you check the distributor on your i4?
Old Mar 28, 2008 | 02:50 AM
josef15111's Avatar
josef15111
maybe a bad ground/power wire some where? just a idea or maybe check to see if you are getting fuel press.
Old Mar 28, 2008 | 12:07 PM
bad venge's Avatar
bad venge
Section Moderator
When you say it seized , you might be right ... sounds like the bottom end has issues causing it to turn slowly
