1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Windows rattling???
Old Mar 30, 2008 | 06:55 PM
finenflyin's Avatar
finenflyin
Default Windows rattling???
To anyone who might know,
Is there anyway to tighten my power windows so that they do not rattle when driving down the road when partially opened? It is quite annoying. Thanks in advance.
Old Mar 30, 2008 | 07:37 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Windows rattling???
sounds like you close the door using the windows ... that loosens/bends the tracks faster then anything ...
Remove the door panel and examine the tracks for signs of bending , if they are bent you'll need new ones ...
if they look good then examine the tracks there are "pads" that are white delrin plastic and are adjustable to provide tension they have a hex head on the outside and a 10mm bolt that "locks" it in place ... if the plastic is missing/broken there's the rattles , if they are all there then they might need tightened to prevent the windows from flapping ... DO NOT overtighten as that can shatter the window , also after the adjustment is done do not use the windows to shut the door
Old May 22, 2008 | 02:17 PM
yanickee's Avatar
yanickee
OK, here is the solution to window rattling!
You will need to remove the door panel and inside window seal! If you look inside, you will see two metal retainers(glass has two plastic hooks that go into the retainers with windows up), both secured with 2x12mm bolts. They are both adjustable. All you have to do is to loosen the 12 mm bolts and use 5/32 allen to adjust the retainers.
[IMG]local://upfiles/13825/742DA547832F48249675E833E4946198.jpg[/IMG]
