1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Why my avenger radomly stops.
Old Apr 26, 2008 | 04:27 PM
nakovka's Avatar
nakovka
Default Why my avenger radomly stops.
Ok. Hey guys question. I got Dodge avenger ES 2000. Sometimes she just stops. I mean power electricly speacking power will be on, but spedometr and odometr will just go to 0's. It's not a battary, i think its a fuel pump relay . Did it ever happend to any one? I am lost and kind of panicking. How can i fix it?
Old Apr 26, 2008 | 04:59 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Why my avenger radomly stops.
If you suspect the fuel pump relay I'd remove the back seat bottom and pop the hatch behind the drivers seat then monitor the wires feeding the fuel pump for 12 volts ... When it dies and it still has voltage it's not that ... If it does lose 12 volts then the relays the likely culprit
I'd also check the white links On the + cable for internal corrosion or the CPS sensor can be intermittant
Old Apr 26, 2008 | 10:37 PM
nakovka's Avatar
nakovka
BUt waht if that is not a fuel pump. what elese could it be?
Old Apr 26, 2008 | 11:09 PM
bad venge's Avatar
bad venge
Section Moderator
I HATE shootguning parts you replaced the huge list , but never really proved what was wrong and infact added other things that could cause it ... need to eliminate ONE thing at a time ...
Old May 4, 2008 | 03:43 PM
nakovka's Avatar
nakovka
Ok so i changed relay, and all the fuse and it stills radomly stops. What else could it be. How can i stop it? I really love the car but it's just dois on me.
Old May 4, 2008 | 08:22 PM
bad venge's Avatar
bad venge
Section Moderator
Again NOT listening Did you CHECK for voltage at the fuel pump or just pop the part in ???
Old May 4, 2008 | 08:57 PM
nakovka's Avatar
nakovka
How do you check the voltage
Old May 4, 2008 | 09:34 PM
Sroufe7's Avatar
Sroufe7
ORIGINAL: nakovka
With a volt meter.
