1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Water in fog light
Old May 15, 2008 | 08:09 PM
fil327's Avatar
fil327
Default Water in fog light
1999 Dodge Avenger ES,I notice water condensation in my fog light. Any recommendation on how to fix it, or do Ijust replace it.
Old May 16, 2008 | 12:22 AM
aveng_95's Avatar
aveng_95
Default RE: Water in fog light
Drill a 1/4 inch hole in the bottom of the fog light housing. This will allow water to drain and air in to dry up any moisture.
Old May 16, 2008 | 11:36 AM
fil327's Avatar
fil327
I was thinking more in the line ofhow to find the leak and sealing it, as putting another hole into the light may justperpetuate the problem.
Old May 16, 2008 | 06:13 PM
PappiDread6's Avatar
PappiDread6
Good luck with finding the hole. The water is just condesation that is built up over time. Its just best to either to replace it or drill a hole like aven mentioned.
Old May 16, 2008 | 09:36 PM
bad venge's Avatar
bad venge
Section Moderator
Throw in oven at lowest setting removing bulb , this will dry out the moisture ...
Take a heatgun and heat up the perimiter and gently pry it apart , put a bead of clear silicone RTV sealant in the crack reassemble wipe extra smooth allow to cure
