1997 Avenger ES stock rims
Alright...have a question.
I am going to be buying some new rims for my 1997 Avenger ES.
Right now I have the stock rims on 205/50/17 tires. I want to purchase a new set of rims that will be going on the same tires. Now...the only thing I'm really worried about is the offset.
How do I find out the offset of the stock 97 Avenger ES rims? Is it printed on the rims somewhere? Does anyone what it is from experience?
I don't want to purchase new rims and have the wrong offset...and cause problems.
Help is greatly appreciated.
ORIGINAL: bad venge
42/44 offset work
42/44 offset work
What about using a 40 or 45 offset, is that pushing it too much? I see more 40/45 offsets for sale than odd numbers like 42/44.
ORIGINAL: Shaigon
Great...thank you.
ORIGINAL: bad venge
42/44 offset work
42/44 offset work
ORIGINAL: silvercoupe97
40 will work on stock height, but if you lower the car it will rub on the rear fender lip and front fender lip during hard wheel compression. I would be afraid of 45s rubbing the upper suspension part(s). Stick with BV's recommendations and you'll be worry free.
I'll use 40 offset if I cant find 42/44, thanks alot guys.
