1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
when do transmissions go out on these?
Old May 16, 2008 | 02:51 PM
91satanslegend's Avatar
91satanslegend
Default when do transmissions go out on these?
i might get a 98 avenger, i was wondering when the transmissions normally go out on these. it has less than 100,000 miles. thanks
Old May 16, 2008 | 06:01 PM
PappiDread6's Avatar
PappiDread6
Default RE: when do transmissions go out on these?
It is usually recomended on cars to do a transmission service every 100,000miles. Just start your care and check your fluid level on the dip stick if its auto also check color as well.
With the manual there is a lil plug above the Driver side CV Axle you can stick you finger in there to check the fluid it level. If you don't know weather it has been serviced or not I would change it before its too late.
