1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
passenger fog light
Old May 20, 2008 | 10:30 PM
redaveng99es's Avatar
redaveng99es
Default passenger fog light
I've always wanted fog lights for my car after seeing other avenger's with theirs. I was at a junk yard about a week ago and saw one and i got it and the switch for $15 so I figured it was a decent deal. But now I need to find a passenger side fog light. If anyone has one they want to get rid of or a great place to buy one let me know.
Old May 21, 2008 | 12:13 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: passenger fog light
be sure to get the right year the 97+ are different then the 95/96 ones
Old May 21, 2008 | 12:22 PM
Mopar.biz's Avatar
Mopar.biz
Do you need the entire lamp assembly or just the lamp???
Thanks,
Kyle
www.mopar.biz
Old May 21, 2008 | 02:49 PM
redaveng99es
the entire lamp assembly or entire fog light, whatever it is. I didn't originally have fog lights so I need the whole thing. Right now all I have is the switch inside the car and the drivers side fog light.
Old May 21, 2008 | 04:46 PM
bad venge's Avatar
bad venge
Section Moderator
If your car didn't come with fogs you'll need the ENTIRE assembly and you might need to WIRE them in as well , some cars came prewired others didnot ... If the car is prewired you need to add the fuse , relay and the switch you bought and the plugs are stashed in the front corners wiring harness ...
Not prewired go get a foglight install kit at the parts store and use that
Old May 21, 2008 | 05:51 PM
dynamiteplaya3's Avatar
dynamiteplaya3
speaking of foglights when changing the bulb does it jsut pull out or what do u have to do to get them out. i have the whole thing apart all i need is to get the bulb off..i have yanked on the damn think and im afraid im gonna break it off
Old May 21, 2008 | 07:25 PM
redaveng99es
yah i need the entire assembly but my car was prewired for fog lights. It already had the connectors by the bumper, the fuse in, and the wiring ran to the dash i just had to put in the switch.
Old May 21, 2008 | 07:33 PM
bad venge's Avatar
bad venge
Section Moderator
Should need a RELAY too ...
